A/C compressor
Old Apr 4, 2007 | 10:43 PM
phatbak's Avatar
phatbak
Default A/C compressor
Hi guys,
I've done a search for a/c compressors but can't find what I need.
the compressor clutch does not turn when I turn on the a/c. (but it spins when I turn it by hand). The fuses at the dash are all good, and so is the fuse & relay under the hood.
My next step was to back-trace the wiring to see if I'm getting power to the compressor...starting at the comp. and head towards the battery. My trouble is
i can't reach the plug at the compressor to test for power. Where would the next logical test point be between the compressor and the fuse block?
I've also read that you can jump the low side switch to turn the clutch, but that didn't work....
TIA
