REMOVAL OF HEADREST...
Old Apr 7, 2007 | 12:38 AM
Richard711's Avatar
Richard711
Default REMOVAL OF HEADREST...
Hi. Anybody knows how to remove the headrest on a Neon 2000?.
Thanks!
Old Apr 7, 2007 | 08:09 PM
djmagic's Avatar
djmagic
Default RE: REMOVAL OF HEADREST...
push the button on top of the actual seat, not headrest and pull up. common sense
Old Apr 8, 2007 | 11:46 AM
Richard711's Avatar
Richard711
Hi. I'm trying the following: "the two tabs at the base of the headrest (where most cars have squeeze tabs) have small holes on the right (from the backseat perspective) - one hole to each gray tab. They are very similar to the one on your computer's CD-ROM. The removal works pretty much like how you would do an "emergency" eject if your cd gets jammed. Except a paperclip didn't work for me... you'll need a thin pointed tool, I used one similar to the car electric tester wand". This processure was suggested by another guy.
You'll need to pull up the headrest as far as it goes - then wiggle the tool around in the hole.
This technique works!!.
Old Mar 7, 2020 | 11:40 PM
Loretta Barber's Avatar
Loretta Barber
Thanks!
how to remove the headrest of a dodge neon 2005
