Exhaust Manifold From R/T on ES?
Old Apr 7, 2007 | 09:06 PM
Izero's Avatar
Izero
Default Exhaust Manifold From R/T on ES?
Hey i was wondering if it is possible to put the Exhaust Manifold from a 2001-2005Neon R/t on my 2001 ES? b/c i found that i can get one fairly cheap from dodgeparts.com so i might consider it... if it will not be a direct fit what would i need to make it fit?
Old Apr 7, 2007 | 09:24 PM
03neonRT's Avatar
03neonRT
Default RE: Exhaust Manifold From R/T on ES?
It will bolt up with no problems...the exhaust ports on the manifold will be much larger than those on your cylinder head, but that only means you wont see as much gain as you would on an R/T.
