Turbo question
Old Apr 12, 2007 | 12:23 PM
2004neonR/T's Avatar
2004neonR/T
Default Turbo question
Ok Im planning on installing A turbo in a couple months I have the timer right now. So would it be ok to install it now to save some headaches later on. So later all I have to wory about is installing the turbo. Or do I have to have the turbo installed with the timer at the same time.
Old Apr 12, 2007 | 12:56 PM
gabo's Avatar
gabo
Default RE: Turbo question
put it like this... if u dont have a turbo, then what are you going to time??
Old Apr 12, 2007 | 01:01 PM
das2123's Avatar
das2123
If you think all you have to install later on is a turbo, then you have alot of research left to do.
Old Apr 12, 2007 | 02:00 PM
tooslow's Avatar
tooslow
you can run the turbo timer without a turbo but it is not gonna do any good
Old Apr 12, 2007 | 02:30 PM
2004neonR/T
I know about all the other stuff that goes along with putting the turbo I know that I have to uprade my engine I was just wondering if you just install the timer without the turbo being there. Also The timer w/o the turbo will still do something it will allow my engine time to cool down before shutting down. Even a stock engines oils should be given time to cool down. I did take a year and a half of engine performance I just missed my certification test by 2 points.
Old Apr 12, 2007 | 02:43 PM
das2123's Avatar
das2123
Damn 2 points!
Just checking on the turbo install, because alot of people think it's as simple as bolting on a turbo and going.
Old Apr 12, 2007 | 02:47 PM
2004neonR/T
Yeah thats what I said when I got the results I was pissed.
