a/c and cooling fan troubleshooting problem
Old Apr 12, 2007 | 07:19 PM
hardlivinlow's Avatar
hardlivinlow
Default a/c and cooling fan troubleshooting problem
ok iv been looking at alldata on this but im still unsure of it. ok my a/c clutch and my engine cooling fan are not kicking on. iv checked all the fuses inside and under the hood and i have replaced the a/c clutch relay and the cooling fan relays and its still not working. the odomitor flashes "Fuse" when you cut the key on but all the fuses i can find are good. and im thinking that the "fuse" warning has something to do with the a/c and cooling fan not working because the PCM controls them relays together. Does anybody know if there is any inline fuse links that i can check because i show all fuses good? the pcm is not giving a CEL beside's that is has been reset with in the last 50 starts, other then that i have no CEL's. kinda hung up on this. and its hot and i need A/C!!! lol.
Old Apr 14, 2007 | 11:23 AM
phatbak's Avatar
phatbak
Default RE: a/c and cooling fan troubleshooting problem
I have the same problem on my wife's '02 https://dodgeforum.com/m_762572/tm.htm
everything looks good, but the compressor clutch will not engage. gonna really try to figure it out today....
Old Apr 17, 2007 | 12:37 PM
hardlivinlow
yeah its got me hung up to. is your cooling fan working? i had to wire mine up direct for now untill i can find the problem
Old Apr 25, 2007 | 12:46 AM
jerry8's Avatar
jerry8
I need to know how to wire the fan directly can you please help?
Jerry
