P0420 what does it mean?
P0420 (M) 1/1 Catalytic Converter Efficency Catalyst 1/1 efficency below required level.
What exactly does this mean, my check engine light came on when i was slowing down to a stop sign after the car had been running and driving for about a half hour. does this mean i need a new cat or something? the cars got 140,000 miles on it.
Any help would be great.
Thanks
Thanks
It means something is up with your down stream o2... Have you installed a test pipe or cut-out?
The upstream reads a paticular value, than the downstream should be reading a lower value due to the CAT. If this doesn't happen then the code is shown.
k3v
When Monitored and Set Condition:
P0420-CATALYTIC 1/1 EFFICIENCY
When Monitored: Engine Run time greater than 90 seconds. Engine Coolant greater than
70°C (158°F) Vehicle speed greater than 20 MPH and less than 55 MPH. Engine Speed
greater than 1216 RPM and less than 1952 RPM.
Set Condition: As catalyst efficiency deteriorates, the switch rate of the downstream O2
sensor approaches that of the upstream O2 sensor. If at any point during the test the
switch ratio reaches a predetermined value a counter is incremented by one. One Trip
Fault.
Fault.
k3v
