Cooling fan running to much
Old Apr 16, 2007 | 11:40 PM
stone1276's Avatar
stone1276
Default Cooling fan running to much
2000 neon with cooling fan that runs almost constanly. fresh coolant and thermostat. anynother ideas? temp sensor?
Old Apr 16, 2007 | 11:41 PM
contagious19's Avatar
contagious19
Default RE: Cooling fan running to much
every how often
Old Apr 17, 2007 | 12:18 AM
spikeymikey87's Avatar
spikeymikey87
does it come on when the car comes on? hows your temp gauge on your cluster reading?
Old Apr 17, 2007 | 12:32 AM
stone1276's Avatar
stone1276
The temp guage is reading normal and the radiator is flowing. It did this through the winter when the temps weree in the teens and twenties. thats why im thinking temp sensor or even the fan it self. this is the wifes car so its stock with low miles.
Old Apr 17, 2007 | 01:00 AM
jeremiah2360's Avatar
jeremiah2360
I noticed my 2001 fan comes on while its still warming up,not on defrost. My temp sensor or whatever could be going too. Doesn`t stay on though,kinda sporatic,doesn`t seem normal.
Old Apr 17, 2007 | 05:08 PM
contagious19
dats normal if ur car is on for a while ull hear da fan turn on and then it would turn off after a lifl bit.
Old Apr 26, 2007 | 02:05 PM
stone1276's Avatar
stone1276
the fan comes on right away even morning starts
Old Apr 26, 2007 | 02:45 PM
Kapitald's Avatar
Kapitald
strange...its not really a problem though (unless it annoys you lol) ... yes check the temp sensor and temp switch..(i believe there are two screwed into the side of the block..one is a switch the other a sensor...) but most people I know want their fans running MORE often to keep the motor cooler...especially when street racing...
Old Apr 26, 2007 | 05:05 PM
00neon27sts's Avatar
00neon27sts
i have a 2000 neon to and the fan kicks on all the time but i autocross so the car get a little warm so i dont worry bout because my temp dont go up so that is a good thing
Old Apr 26, 2007 | 05:22 PM
Biged83's Avatar
Biged83
i just had to have my cooling fan motor replaced
