01+ Hydraulic Transmission questions
Old Apr 17, 2007 | 01:40 AM
night709's Avatar
night709
Default 01+ Hydraulic Transmission questions
I have a 01' neon and was wondering what parts are needed to switch over to a manual hydraulic transmission from an auto? Which manaul transmission should I get for the switch?
Old Apr 17, 2007 | 01:43 AM
night709's Avatar
night709
Default RE: 01+ Hydraulic Transmission questions
I meant to say hydraulic clutch...lol
Old Apr 17, 2007 | 05:30 AM
03neonRT's Avatar
03neonRT
You will need the following for an MTX swap (theses are the general parts you will need): transmission (3.55 from 01-05 or 3.94 from 01-04), modular clutch, passenger side axle, clutch master and slave cylinder, shifter cables and clips, tranny side motor mount from a manual transmission 2nd gen, MTX PCM from your year car, shifter and shifter base, clutch and brake pedal assembly from a 2nd gen.
Old Apr 17, 2007 | 06:30 AM
night709's Avatar
night709
Thank you.
