single exhaust setups?
Old Apr 28, 2007 | 08:28 PM
l_pillon's Avatar
l_pillon
Default single exhaust setups?
anyone just runnin a single exhaust instead of the duals....just wondering which brands offer the single exhaust...i have a 2000 neon and all i seem to find are the duals(magnaflow,borla,vibrant etc)
Old Apr 28, 2007 | 08:58 PM
ewetho's Avatar
ewetho
Default RE: single exhaust setups?
Thermal makes on that is dual tipped but both are right next to each other on the RH side of the car. Check out Modern Performance
Old Apr 29, 2007 | 06:47 PM
Pablodragon's Avatar
Pablodragon
maybe this was where he got the question...
was also wondering the same thing...BECAUSE...looking at the stock exhaust setup, it come out-over the rear axle- on the drivers side...then you get the bend and the big muffler sideways, then it exits the passenger side. Doesn't sumone make a direct bolt-on that uses the stock hanger, but just bolts right up to the pipe over the axle, then come straight back, with the new muffler parallel to the pipe, then exits with a tail-pipe on the drivers side? Looks like a no-brainer aftermarket idea....
Old Apr 29, 2007 | 08:51 PM
lblackneon's Avatar
lblackneon
There is also the Tsudo stainless steel exhaust with 1 tip and the Dynomax aluminized steel with 2 tips. Both come out on the right side.
Old Apr 30, 2007 | 12:40 AM
Andpto's Avatar
Andpto
just slap on a fart can and you will have single exit exhaust. JK
