r/t manifold? (is this??)
It will fit your your non R/T just fine... You won't be able to use the R/T gasket though. get a new non-magnum gasket. I port matched my new non-magnum gasket with a dremel before i put it on.
k3v
k3v
I was actually going to purchase a r/t header a while back. $75 was the price. I would say go for it. It isn't an amazing deal but it is a good one. It would be hard to find it less than $75. 03neonRT told me that the r/t header should bolt right up to our stock manifold gasket, but if not the r/t gasket should work. If the header is coming with the exhaust manifold gasket it is a good price [8D]
