Exhaust Concerns...
Old May 8, 2007 | 12:54 AM
Kalevra's Avatar
Kalevra
Default RE: Exhaust Concerns...
you took out your cat? damn! im about to get a high flow cat
Old May 8, 2007 | 01:00 AM
tooslow's Avatar
tooslow
don't bother with the high flow the neon cat flows pretty good and if go too free flowing with the exhaust you will loose power down low. Unless you go turbo then no backpreure= good
and if you want mod that gives both power and gas milage get a under drive pulley.
Old May 8, 2007 | 01:03 AM
Kalevra's Avatar
Kalevra
I see, so to conclude this... the srt4 back pipe (straight piped)wont hurt my engine? and I dont need the o2 sensor or new ECU at all?
Old May 8, 2007 | 01:12 AM
spikeymikey87's Avatar
spikeymikey87
no you are fine. technically since you still have a cat, that is providing enough back pressure, so you are not running a free flow exhaust. you will be fine
Old May 8, 2007 | 01:16 AM
Kalevra's Avatar
Kalevra
it's just a stock SRT4 back pipe I have on there. everything before the back pipe is stock.
Old May 8, 2007 | 02:10 AM
AirWolf's Avatar
AirWolf
Well right now since I changed too new plugs and wires with all my mods I now get 29 in the city and 35 highway so the srt exhaust has not hurt my gas mileage its helped out nicely especilly with a glasspack on her.
Old May 8, 2007 | 02:54 AM
Adionik's Avatar
Adionik
The srt exhaust will decrease your gas mileage due to flooring.
trust me.
Old May 8, 2007 | 04:14 AM
Kapitald's Avatar
Kapitald
yes your friend is correct you lose backpressure and will lose performance....BUT it wont hurt your motor or anything else and you will not need what he said....to keep your performance just install a glasspack muffler they are cheap and you can get it done at your local muffler shop...I would get a glasspack muffler if I were you.
