P0171
Old May 9, 2007 | 11:31 PM
Fantasticle's Avatar
Fantasticle
Default P0171
P0171 Fuel Trim System Lean Bank 1,
whats this mean? I changed my fuel filter/regulator and then this came up. Im not sure what it means anyone know?
Old May 10, 2007 | 12:07 AM
03neonRT's Avatar
03neonRT
Default RE: P0171
Start by checking your 02 sensors...its basically saying a lean air fuel mixture has been detected so its dumping much more fuel into the mixture to correct the lean A/F mixture.
Old May 10, 2007 | 01:31 AM
Fantasticle
Default RE: P0171
hm, im only getting 9 psi when i hooked up a gauge to the end of my fuel rail. For my year, 2000, im supposed to be getting 44-54 psi, for newer 54-63. so I dont think its dumping too much gas because theres not alot of pressure in my system. I changed the Fuel filter today so i ordered the pump today since nothing changed, well i did get 1 more psi (9 vs 8) but nothing big. I can hear the pump kick on but I think its failing. I'll check my O2 sensor tmrw just in case, so it doesnt cost me 200 bucks. thanks man
