Water LEaking In Trunk!! HELP ASAP!!!!
Old May 17, 2007 | 03:40 AM
technical18's Avatar
technical18
Default Water LEaking In Trunk!! HELP ASAP!!!!
Like the title says i have a small amount of water in my spare tire well.
From what ive read on this and other forums is that its the rear tail lights and the best way to fix it is to use some silicon gel around the seals...
my problem is i dont know where exactly to seal the lights...i've read that some people took the lights out, and ive read that some people just put a seal around the top and side edge of the light without having to take em out
Can someone circle where im supposed ot seal these things in these pics ive taken?
http://i19.tinypic.com/6ew175w.jpg
http://i1.tinypic.com/53ffxfs.jpg
http://i14.tinypic.com/4oqk86h.jpg
i'd rather not take the lights out if i dont have too
Old May 17, 2007 | 03:53 AM
Izero's Avatar
Izero
Default RE: Water LEaking In Trunk!! HELP ASAP!!!!
man get the hell outa here..... get yourself a rachet and take the three freakin' bolts out of the back of the tail like and pull the stupid thing out..... look at the black ring type thing if it looks scaley or dry rotted go buy yourself some cheapo tail lights on ebay and save yourself a head ache......
Old May 17, 2007 | 03:59 AM
Freerider's Avatar
Freerider
ORIGINAL: Izero
you seem angry...
Anyways!!
There are 3 sources for the leaking.
One source is a leak coming through holes for the screws from the spoiler! You check to make sure nothing is coming from that.
A second source for leaking is from the trunk seal. Check that and make sure it is ok.
The third and last is the tail light seals. You can fix it by buying new seals or new tail lights.
Old May 17, 2007 | 04:01 AM
Izero's Avatar
Izero
lol sorry commin off the buzz and left this page open and saw it :-P lol i just remember seeing the same thread a few diff times here.... but its all good
Old May 17, 2007 | 04:12 AM
technical18
ok so new tail lights would fix the problem?
cause i had planned on getting new ones soon anyway
Old May 17, 2007 | 04:19 AM
Izero's Avatar
Izero
well if thats the problem in the first place then yes... it would fix the problem..
Old May 17, 2007 | 11:49 AM
technical18
think i fixed the problem.
MOD CAN CLOSE THIS!!!!!
