help with neon
200 neon have had starting problems for a while, have to play with the gas pedal to get it to start, then has idle problems, seems to run ok once you get it started, found a smashed seal on the intake manifold and signs that it was leaking, now same problem, no codes, but beginning to think it is the map sensor, any thoughts?
Thanks, i know what the code is have replaced the sensor, have removed the intake and cleaned, still same code same problem, is it possible PCM or wiring problem, does anyone have wiring diagrams of sensor wiring
