Rear door panel removal
Old Jun 15, 2007 | 09:22 PM
nd4spdgtp's Avatar
nd4spdgtp
Default Rear door panel removal
I need help as soon as possible
I have an 00 neon and I need to take the rear door panels off but how do you get around the manual window crank handle...I think that's what it is or I'm just naming it for myself lol.
Any helps with diagrams or anything would be of help.
Thanks
Andrew
Old Jun 16, 2007 | 03:04 AM
Izero's Avatar
Izero
Default RE: Rear door panel removal
you need a tool used to take the clip behind the crank.... but a thin pair of needle nosed pliers should do the trick, there is a tiny clip behind the crank that you need to pop off, but be carful because it will seriously fly away if you dont have ur hand on the other side to catch it, i hope that helps....
Old Jun 16, 2007 | 04:13 AM
neon 05's Avatar
neon 05
yea just twist it around to see the butt of the metal clip and with a flate head tip or a nose clip as izero said it pop out easy!!!play wit it
