Hard Start on 2000 Neon
Old Jul 1, 2007 | 06:04 AM
Izero's Avatar
Izero
Default RE: Hard Start on 2000 Neon
now is it hard to start it when it is cold or hot out? (yes it makes a difference)
Old Jul 1, 2007 | 02:27 PM
BevinZX3's Avatar
BevinZX3
It's hard to start in either hot or cold. But lately I've been noticing it more, since it is summer time and half of the week it sits outside. I will try the on position trick though and see if that does help.
Old Jul 1, 2007 | 06:51 PM
Izero's Avatar
Izero
well it could be a timing issue you might want yo get your timing checked out by a mechanic.... it could be a bad coolant temp sensor, the MAP sensor could have went bad, the fuel pump might not be working correctly, the injectors could be leaking... thats about it i think so you may want to check those as well.....
