rims fit?
Old Jun 30, 2007 | 09:54 PM
LilRedNeon97's Avatar
LilRedNeon97
Default rims fit?
anyone know if 16" rims off a subaru (impreza, i think) would fit a 02 neon? the bolt pattern is 5x100.
Old Jun 30, 2007 | 10:34 PM
contagious19's Avatar
contagious19
Default RE: rims fit?
i think they will. wats da offset
Old Jun 30, 2007 | 11:01 PM
LilRedNeon97
not sure. there are tires on them at the moment so i cant check the rim itself. do you know the range that is ok for the neon??
Old Jun 30, 2007 | 11:02 PM
Freerider's Avatar
Freerider
its ok between 35-45 but I would not put them on unless they were 38-42mm
Old Jul 1, 2007 | 12:42 AM
Izero's Avatar
Izero
whats the bolt pattern on the WRX.... isnt it 114.5x5? or is it the same as our neons, 5x100.....?
Old Jul 1, 2007 | 03:25 AM
Tomlintm's Avatar
Tomlintm
ORIGINAL: LilRedNeon97
as long as the wide of the rim is s 16x7 or less you will be fine and the bolt patern is the same.
