ticking
Old Jul 5, 2007 | 06:31 PM
00neon27sts's Avatar
00neon27sts
Default RE: ticking
wow thats scary to know
Old Jul 5, 2007 | 07:37 PM
Exubus's Avatar
Exubus
Default RE: ticking
ORIGINAL: 00neon27sts
is it just neon or is the something wrong when my car is running it ticks is therea problem or is it normal its a 2000
It's normal for Neons. There is a way to fix it, which I posted a few weeks back... but that's only if you can't live with the noise. In most cases, the usual "Neon tick" that you are hearing is actually not affecting your performance whatsoever, believe it or not. The rockers like to walk side-to-side on the pivot shaft... that's the tick you hear. The tick is not from the rockers going up/down on the valves. Do regular oil changes and it should never actually affect your performance.
