Programming Additional Keyless Entry
Hi, I would like to know what is the procedure to program an extra Keyless Entry if you have one already programmed? I've been reading that its not necessary to go to the dealer if you have one already workingbut haven't found the procedure for it in this forum.
Is there a limit as for how many Keyless you can have programned at once?
And is there anything special I have to look for when buying an extra remote from Ebay(not the dealer), since Ive readon ebay that there are someremotes that can look the same but dont really work on all Dodge/Chrysler cars.
I found the HOW TO at 2gn.org
Here's how in case somebody else needs it:
"Ok, this is from the 2000 Neon owners manual.
Additional transmitters can be programmed to the system using the following procedures:
1. Insert the key into the ignition and turn the switch to the run position.
2. Press and hold the Unlock button on the transmitter for between four and ten seconds.
3. Continue to hold the Unlock button and press the Panic button. A chime will sound to indicate that the transmitter programming mode has been entered.
4. Press a button on all transmitters to be programmed to the system, including any previously programmed transmitters. A chime will sound when each transmitter has been programmed.
5. Turn the ignition switch off to exit the transmitter programming mode."
Iused this to program my 2nd Gen Neon, with one existing remote.
Program Method A (Customer Program Method)
[ol][*]Press (LOCK) button 5 times at 2 second intervals to resynchronize transmitter. Attempt to function transmitter, if working as designed discontinue programming.[*]Turn ignition to run position. (Allow ignition chimes[UNLOCK] to stop).[*]Using any original (working) transmitter, press the [UNLOCK] button for 4 to 10 seconds.[*]Within the specified 4 to 10 seconds, continue pressing the [UNLOCK] button and press the [PANIC] button for 1 second and release both buttons (AN/DN release either button first). A chime will sound to indicate that the transmitter programming mode has been entered (allow 3 seconds for chime to sound).[*]Press [LOCK] and [UNLOCK] buttons simultaneously for 1 second and release (a short chime will sound for AN/DN).[*]Press and release any button on the same transmitter and a chime will sound after successfully programming the transmitter (locks will cycle for AN/DN). [/ol]NOTE:(FOR DR ONLY) A CHIME WILL NOT SOUND ON STEP # 6 FOR THE FIRST TRANSMITTER PROGRAMMED, BUT WILL SOUND UPON PROGRAMMING THE SECOND TRANSMITTER.
[*]Repeat steps 5 through 6 to program additional transmitters.[*]Turn ignition to OFF position. Transmitter programming mode v/ill discontinue after 60 seconds (30 seconds for AN/DN and RS). (All transmitter programming must be completed within time specified). [/ol]
Program Method B (Customer Program Method)
[ol][*]Press [LOCK] button 5 times at 2 second intervals to resynchronize transmitter. Attempt to function transmitter, if working as designed discontinue programming.[*]Turn ignition to the run position (Allow ignition chimes to stop).[*]Using original transmitter, press and hold the [UNLOCK] button on the transmitter for between 4 and 10 seconds.[*]Continue to hold the [UNLOCK] button and press the [PANIC] button. A chime will sound to indicate that the transmitter programming mode has been entered (Allow 3 seconds for chime to sound).[*]Press a button on all transmitters to be programmed into the system including any previously programmed transmitters; a chime will sound when each transmitter has been programmed.[*]Turn the ignition to OFF position to exit the transmitter programming mode. [/ol]
Program Method C (Dealer Program Method) *Can be used for any type transmitter.
[ol][*]Press [LOCK] button 5 times at 2 second intervals to resynchronize transmitter. Attempt to function transmitter, if working as designed discontinue programming.[*]Turn ignition to the run position (Allow ignition chimes to stop).[*]Plug DRBIII to vehicle's 1-way data link connector.[*]Follow Service Manual and DRBIII instructions to program transmitters. [/ol]
Program Method D (For use with AB vehicles not equipped with VTSS only)
[ol][*]Locate the dark green program enable wire connected to pin # 1 of the 16-way data link connector under the left side of the instrument panel.[*]Connect the program enable wire terminal to a good ground.[*]Insert the key into the ignition and turn the ignition switch to the ON position. The power locks will cycle (Lock and Unlock) indicating that program mode has been entered.[*]Using the transmitter to be programmed, press either [LOCK] or [UNLOCK]. The power locks will cycle indicating the transmitter has been programmed successfully.[*]Repeat step 4 to program additional transmitter.[*]Disconnect the program enable wire from ground to exit program mode.[*]Turn the ignition to the OFF position and remove the key. [/ol]
