engine swap ideas?
Old Jul 25, 2007 | 03:37 PM
Jeffmarble's Avatar
Jeffmarble
Default engine swap ideas?
hey all im in the preliminarys of swapping the motor on this neon but was curious on what you guys think would be a better swap my first option is using some parts i already have i plan on a rear wheel drive swap.
first option is using my 348 stroker i got laying around a older dakota rack and pinon tf727 and 8 3/4 rear open dif i have some other misc parts but thats the majors
or i can look for something else since i found a place i can get wrecked newer vechicles for fairly cheap 3-5 grand. crossfire v-6 maybe a caliber awd? what would you guys think would be i better idea the first option drops me out of the smog arena but i do believe a newer motor such has those maintaing smog equip should pass bar its a 05 neon and id rather not go the srt route alittle common. i know both require massive mods but it has been done before and ive toyed with a v8 isuzu swap i did a while back so its possible for me to do it
[align=left] [/align]
Old Jul 25, 2007 | 03:38 PM
Jeffmarble's Avatar
Jeffmarble
Default RE: engine swap ideas?
btw itll probably take a year or so
Old Jul 25, 2007 | 04:11 PM
Izero's Avatar
Izero
well you are gonna have to do some major modifications to make it RWD.... but i'd love to know what motor you choose.....
Old Jul 25, 2007 | 05:05 PM
Sawhiskey's Avatar
Sawhiskey
As said above it would be awesome to see what motor you choose, and rwd neon sounds fun to drive.
Old Jul 25, 2007 | 05:33 PM
Jeffmarble's Avatar
Jeffmarble
its a toss up but id like some input i wonder if i could find a cross fire rt ive seen first gens with all sorts of swaps 440's subi motors and i know the biggest interior mod is the driveshaft tunnel all were the case perhaps a crossfire may be a better choice good to find a srt front clip and try and scavange has much has possible possibly retrofitting the cross fire crossmember and front suspension to the neon smaller v-6 means less of a clearance issue with the front radiator
Old Jul 25, 2007 | 06:22 PM
blackflame's Avatar
blackflame
I have heard there isn't much room at all for a driveshaft to go to the back. So yeah, it would be a lot of work but is would be really cool if you pulled it off.
