struts
are kyb-gr2 struts good for lowering
RE: struts
Struts don't exactly lower your car. Springs or coil-overs would do that.
RE: struts
You're asking if they can take the pressure of a lowered car right?
RE: struts
yes exactly.... will i be able to put lowering springs on them for a good combo
RE: struts
They can, but the Tokico HP Blues will be a better option for a lowered 2nd Gen.
RE: struts
will they bust under the pressure of a lowered car
RE: struts
The KYB GR-2's will hold up slightly better then OEM replacement struts. If you want struts that will last under the stress of lowered suspension, then spend your money the right way and purchase the Tokico HP Blues.
RE: struts
talking about the kyb struts.................
RE: struts
ORIGINAL: THExRED talking about the kyb struts................. ORIGINAL: 03neonRT The KYB GR-2's will hold up slightly better then OEM replacement struts. |
RE: struts
awesome..... are the blues compatible with other springs besides the ones they come with
