Wheel Alignment
Old Aug 13, 2007 | 08:26 PM
spikeymikey87's Avatar
spikeymikey87
Default RE: Wheel Alignment
67.99 at sears auto center plus a 6 month waranty with no questions asked
Old Aug 13, 2007 | 09:14 PM
neon03se's Avatar
neon03se
awesome i get an employee discount at sears!!!
Old Aug 13, 2007 | 11:20 PM
Adionik's Avatar
Adionik
ORIGINAL: spikeymikey87
I got an alignment a LOOOONG time ago when i first got my car, switched to srt struts a few weeks ago and then went back.
The guy was like, "Oh man the camber was WAYYY off. It was bad. it was BAAD. Those damn pot holes".
Old Aug 14, 2007 | 11:13 AM
03neonRT's Avatar
03neonRT
ORIGINAL: Adionik
Lol.
Old Aug 14, 2007 | 01:00 PM
neon03se's Avatar
neon03se
so it can be done on a lowered car then?
Old Aug 14, 2007 | 08:54 PM
contagious19's Avatar
contagious19
well u need to get an alignmentwhen u lower da car.
Old Aug 14, 2007 | 09:02 PM
03neonRT's Avatar
03neonRT
ORIGINAL: neon03se
Yes, an alignment can and will need to be completed when you install lowering springs, struts, etc...if the drop is more extreme (i.e. 2"+) you will need camber correction bolts, but generally anything under a 2" drop you should be fine without them.
Old Aug 14, 2007 | 09:35 PM
neon03se's Avatar
neon03se
i took it to a shop and they said that the car was too low, is that what the bolts are for?
Old Aug 14, 2007 | 11:16 PM
das2123's Avatar
das2123
ORIGINAL: neon03se
To low for what? The "crash" bolts are to adjust camber.
Old Aug 14, 2007 | 11:28 PM
PICKLEZ's Avatar
PICKLEZ
I asked my tech he said lowered cars are ok and prices can range from 45 to 70 here in maine. go to sears!
