Atx Problem
Old Aug 17, 2007 | 04:28 PM
Jerry23's Avatar
Jerry23
Default Atx Problem
My Trans wont shift out of 2bd up or down. went to autozone they ran the code reader on it. It came as PO700 and PO 750? Can someone tell me what i need to do?
Thanks,
Jerry
Old Aug 17, 2007 | 06:56 PM
spikeymikey87's Avatar
spikeymikey87
Default RE: Atx Problem
p0700 means that there is something malfunctioning with the trans
p0750 says shift solonoid a is malfunctioning.
i would say you need to change the solonoid out and you should be fine
Old Aug 17, 2007 | 07:01 PM
03neonRT's Avatar
03neonRT
I agree with Mike on this one, and for future reference, your gauge cluster can display the trouble codes that the PCM is throwing. No Scantool required...
Old Aug 17, 2007 | 07:03 PM
spikeymikey87
yea just turn the key on-off-on-off-on and then it will show up
Old Aug 19, 2007 | 12:53 PM
Jerry23's Avatar
Jerry23
thanks for the response. I'll try that and see what happens.
Old Aug 20, 2007 | 02:20 PM
Jerry23's Avatar
Jerry23
went to oreillys and got the part. now i cant find it on the transmission. Can you tell me where it is or point me to someplace that i can see it?
Thanks
Jerry
Old Aug 20, 2007 | 03:01 PM
NHARINTON's Avatar
NHARINTON
take out you battery and intake assembly, all the tranny sensors are right thier..... not sure exactly witch one it is... i am on vaction and cant look at it. I belive a chilton manuel says. Otherwise pull one and if its the same thier ya go, if not check the next one. And dont worry no fluid will leak out unless the trans is way over full. By the way have you checked the fluid level???
Old Aug 24, 2007 | 04:14 PM
Jerry23's Avatar
Jerry23
got the solenoid shift pack from dodge and changed it. still not shifting and still throws the p0700 code. trans fluid is topped off. speedo reads right. maybe the input speed sensor? i dunno. disconnected the battery and cleared the code. drove 100 ft and threw it again.
thanks
jerry
