Headlight question
Old Aug 22, 2007 | 07:38 PM
night709's Avatar
night709
Default Headlight question
Would it be a bad thing to try to take them apart and fix them? I have a 01' neon and halo headlights. Some of the halo's and lights on the side don't light up. Would it be easy to take apart and fix them?
Thanks for the help.
Old Aug 23, 2007 | 01:08 PM
ricerchik02's Avatar
ricerchik02
Default RE: Headlight question
Well, if it isn't working that well anyways, then I don't see the problem with tinkering with it. I like to tinker with things and I usually can fix them. Do you think it could be a problem with the wiring? Maybe you didn't soder the wires when you installed them or maybesomething came loose. [sm=signs003.gif]
Old Aug 23, 2007 | 02:45 PM
contagious19's Avatar
contagious19
return dem if dey dont work. or did u connect it right?
