Turn signals not working...
Well I installed a new old cluster and took it out for a test drive, ran well and whatnot, I got back turned the car off and turned it back on a lil while later and the turn signals, dome light (on mfs) and hazards don't work. I checked all the fuses and they all looked good, bought a flasher relay and still the same :'(. I looked at the harness for the lights and it looks a little melted... Is the multifunctional switch dead or wha? The headlights turn on and breaks work. Can anyone help me out?
Hmm, I think i may have found What the problem is. I'm thinking that the turn signal flasher on the actual multifunction switch died on me. So my question now is, if I throw in a new one will it just go out again? Like I said before, this happened after I installed the cluster--could it be the cluster that did this?
