No rear lights???
Old Sep 3, 2007 | 09:30 PM
chazlewood75's Avatar
chazlewood75
Default No rear lights???
When I turn on my headlights, none of the rear lights come on. I checked the bulbs. The only one that looked burnt was the middle light. I replaced it. I checked all the fuses in the compartment on the left side of the dash as well as under the hood. They are all fine. I checked the turn signals and brake lights and all come on. But at night when I turn on my headlights, nothing on the rear comes on. Also, when I would unlock my car using the remote, the tail lights would flash. They no longer flash. It was shortly after I discovered that when I found out that I had no rear lights for night driving. Anyone have any ideas?
Old Sep 4, 2007 | 06:11 AM
Yako's Avatar
Yako
Default RE: No rear lights???
a fuse probly
Old Sep 4, 2007 | 09:29 AM
chazlewood75
All fuses look good. I checked the panel on the left side of the dash as well as the panel under the hood.
Old Jan 31, 2008 | 02:37 PM
chazlewood75
I could not find a bad fuse or buld anywhere. Somehow a wire got disconnected from the inside fuse box. After splicing it back into the box, the rear lights worked again. It ended up costing me $55 for 1 hour's work at the dealership.
