Font of the car,
Old Sep 15, 2007 | 08:29 AM
Rodge57's Avatar
Rodge57
Default Font of the car,
makes this squeeking nosie when I hit bumps when I turn the car. I think it's the struts. 2005 Dodge Neon SXT less then 33k on it. I can push down on the car on the outside and it does it. Both sides. Back is not doing it. Any help?
Old Sep 15, 2007 | 08:40 AM
Mike594sxt's Avatar
Mike594sxt
Default RE: Font of the car,
Struts shouldnt be doing that with only 35k on the car. Could be a few other things as well though.
Old Sep 15, 2007 | 08:41 AM
bone33's Avatar
bone33
look under, in the wheel wells and see if the strut shaft is making contact with thestrut tower mounting plate. you will have to pull back the boot.you can verify this is the issue by spraying a little wd40 on the shaft, if the problem goes away, then all you gotta do is adjust it.
Old Sep 15, 2007 | 05:00 PM
Swordfish2Cowboy's Avatar
Swordfish2Cowboy
Change it to Arial or Times New Roman. Never, and I mean NEVER use anything Courier.
Also, the blue helps.
Old Sep 15, 2007 | 05:05 PM
Izero's Avatar
Izero
ORIGINAL: Swordfish2Cowboy
just smack yourself please...... right across the face....
as for your problem, i'd try the WD-40 after a visual check for contact of parts... good luck
Old Sep 15, 2007 | 06:11 PM
Adionik's Avatar
Adionik
check your bushings...
