Washer
can you hear the pump working? I had a problem with the lines getting pinched or the nozzles getting clogged. Trace the rubber hoses and take off any plastic connectors to check for clogs. Also take a pin/needle and stick it in the hole of the nozzle to clean out any dirt or salt. (i lived across the street from the beach - alot of salt)
Yea I talked to a friend an he recommend to do a 12 volt test on it too. Imma clean them and check lines, I did look at the pump once and everything looked good. Thanks man
And yeah I have been doing that bone, Ha.
