odd front end noise
Old Sep 24, 2007 | 07:42 PM
crobi2002's Avatar
crobi2002
Default odd front end noise
Hi all,
I recently purchased a 2002 neon sxt, and have an odd noise coming from the front end. It sounds like a cross between grinding and a bad rubbing, and occurs mostly right after start up on acceleration and going over dips. I replaced the torsion mounts, as the rubber was seperated from the metal. visual inspection shows nothing out of the ordinary underneath the car, with the possible exception of the control arm bushings. Has anyone experienced anything like this, or know where I should start looking?
Thanks,
Chris
Old Sep 24, 2007 | 08:43 PM
bone33's Avatar
bone33
Default RE: odd front end noise
check your CV joints.
also, does it do it while your are backing up while turning in a circle?
