How do I get to my speakers?
if you want to do it right, according to posts on this board, the whole rear seat -bottom and back- is supposed to be removed to properly get at that top shelf carpet and speakers mountings...
maybe do a search on here for "rear speakers"....
i did it... depends if you just wanted to replace the speakers or do you want it in a way so that the grill is on top of the mat and can be seen. if it's just regular replacement then it's easy... first take off the bottom rear seat... just pull it up... easy... then you'll see the rear seat is bolted on along with the seat belt by 3 large bolts (star shaped) once those are off... then you slide the back seat off by sliding it upward then out... then you have access to the rear mat that's covering the speakers... take those off... and wahla... you get to the speakers. reverse and put everthing back... then you're done. If you want the grill or speaker to show through the mat... then you'll need to cut holes in them and match to the size of the speakers.
Maybe Dodge just wants you to believe that is the only way so that you will pay someone else to do it...scammers!!!
But yea, I thought all u had to do was remove the carpet cover from behind the seat, thats the way I did it with a Monte Carlo and tho cars are different, it seems like that is the way u could do it with a Neon. It there something that makes removing the seats absolutely necessary?
ricerchic: if i remember correctly the carpet folds down behind the top of the seat, and u cant move the seat far enough to pull it off.
yea dodgeneonz is right. pretty much the hardest part for me was cutting the holes, that andremoving, inserting the screws that hold in the speakerslol.
Trending Topics
ORIGINAL: ek2588
