Loation of Starter Relay
Old Oct 8, 2007 | 10:44 AM
JohnnyRSX's Avatar
JohnnyRSX
Default Loation of Starter Relay
I have a 2000 Neon LE that does not start, I've had the starter replaced and still no good. I know the battery and altenator are all working fine. I want to replace the starter relay but don't know where the location is? There is no crank, however sometimes it does crank but won't turn over. Majority of the time there is no crank. Thanks!!!!
Old Oct 8, 2007 | 12:51 PM
03neonRT's Avatar
03neonRT
Default RE: Loation of Starter Relay
The starter relay is int he main box under the hood right next to the battery. On the back side of the cover there will be a diagram that lists what each relay is for so you can locate the right one...
Old Oct 8, 2007 | 02:15 PM
JohnnyRSX's Avatar
JohnnyRSX
Thanks 03neonRT, I have another question, another possibility is the neutral safety switch and ignition switch may be intermittent, do you know the location of these parts and the difficulty in replacing them? Thanks!!!
Old Oct 8, 2007 | 02:38 PM
03neonRT's Avatar
03neonRT
The neutral safety switch is located here:
The ignition switch is here:
