Help: Squeaking from wheel well
Old Oct 11, 2007 | 07:37 PM
BDM's Avatar
BDM
Default Help: Squeaking from wheel well
Lately I have been experiencing a Squeaking noise/chirp from my front drivers side wheel well. I hear it when I go over bumps, random moments, and almost always when I am turning right. I inspected my brake pads and are a long way away from needing replacements. When it chirps, it chirps for every wheel revolution. The chirping goes away during any of these circumstances when I apply the brakes. Can anyone help me?
Old Oct 11, 2007 | 08:41 PM
Kalevra's Avatar
Kalevra
Default RE: Help: Squeaking from wheel well
CHECK YOUR CAI!!!!!
it could be rubbing against the edges of the hole in the fender
that could be it
Old Oct 12, 2007 | 02:17 AM
BDM's Avatar
BDM
It's fine...I'm still convinced it's a brake issue[&:]
Old Oct 12, 2007 | 12:07 PM
Rodge57's Avatar
Rodge57
I fixed the problem today. The rubber bushing that connected to the A frame was rubbing together. Mine was doing it on both sides. I just took WD-40 and sprayed on the rubber. Fixed them both. So it wasnt the struts.
Try that I think I had the same problem.
Old Oct 13, 2007 | 12:48 PM
BDM's Avatar
BDM
Okay I got some WD-40...where exactly do I have to spray? I'm confused
Old Oct 15, 2007 | 11:24 PM
neonmanbp's Avatar
neonmanbp
bump
