2002 Neon SXT radiator help
Old Oct 18, 2007 | 12:03 AM
bmil03's Avatar
bmil03
Default 2002 Neon SXT radiator help
Yesterday my girlfriends car's radiator started leaking on the bottom of the drivers side corner. It was leaking where one of the hoses from the transmission goes in. I look a little closer and the hose was very loose where it entered the radiator, and I could wiggle it around easily. Now I don't mean that the hose clamp was loose, but the threaded end that entered the radiator didnt seem as tight as the other one. So I need to know is this an issue with the radiator where I will need to replace it or is the issue a damaged hose? Please help ASAP!
