E - Brake light comes on intermittently when I shift into first
Old Nov 2, 2007 | 12:24 PM
ascendingmango1's Avatar
ascendingmango1
Default E - Brake light comes on intermittently when I shift into first
Hello all,
I was searching the internet on a problem I have and didnt come up with much, so I figured I would leave a post somewhere and hopefully someone could give me some guidance. Hopedully I came to the right place.
Recently when Istart from neutral into first, as soon asI push all the way into gear, the E brake light comes on and chimes at me... wtf? A bad ground somewhere maybe?
It only does it whenI go into first gear. The light usually it shutsoff whenI shift into second, but sometimes stays on till 5th. The E- Brake is definatly not engaged, hell ithasnt worked sinceI bought the car a year ago (the cable is broken somewhere along the way)-I just leave it in gear when parking.Any ideas on what it could be?
Secondly, When I start my car the word "FUSE" flashes where the odometer is normall lit. This one baffles me... Any ideas?
I hate to be the new guy that comes in just to ask a question, but I cant find info anywhere else. Any input would be appreciated.
Thanks
Old Nov 2, 2007 | 06:23 PM
tooslow's Avatar
tooslow
Default RE: E - Brake light comes on intermittently when I shift into first
if only does it when you away fast then just top of your brake fluid it is brobly low and when you pull away it the fluid moves back and the senser thinks the fluid is low my car did thesame thing
Old Nov 4, 2007 | 02:32 PM
ascendingmango1
yup, that was it.
thanks
