wiring question
Old Nov 2, 2007 | 11:20 PM
athespen's Avatar
athespen
Default wiring question
I have a quick question on general wiring for things such as interior lights (like neons) and/or exterior lights (such as neons as well).
I think I may have the general idea, but I am not sure. I bought switches that have 3 prongs, and on the side of the switch, there is a sticker that says what each prong is for. One for power, one going to the lights or whatever, and one to ground. So, my question is, do I run a wire from the fuse box to the switch, then run the ground from the switch to a nearby screw or something, then just run a wire from the switch to the light and run a ground wire for the light as well? If I have to run a wire from the fuse box, what is the best way at connecting the wire to it and what one should I run it to if I was to put interior or exterior neons on my vehicle?
Old Nov 3, 2007 | 12:51 PM
spikeymikey87's Avatar
spikeymikey87
Default RE: wiring question
i would leave the ground wire from the switch out of the equation all together. unless the switch works by taking the ground away and constantly giving power. i would check that out first. take a test light, if you dont have one, use the loght you ate hooking up and just wire it to the battery and see what combinations of wires is good
