Oil in spark plug
Old Nov 13, 2007 | 06:03 AM
dodgeneonz's Avatar
dodgeneonz
Default Oil in spark plug
Ok, so since after i bought the powercoated valve cover from mencingracing or was it meganracing? I've been getting oil in the tube thing that runs with your spark plug (not sure what you called them). Everytime i take out the sparkplug wires from the tube there's always oil in them and it seems like the oil is actually flowing downward because there's more oil on the top of the sparkplug wire tube than at the bottom. When i got it i only switch over the gasket that's around the valve cover (the long thin rubber)... did i miss some other stuff that i have to switch over? seems like the oil is spilling out from the gap between the valve cover and the sparkplug tube. Any idea? oh and it didn't do that before i switch the valve cover.
Old Nov 13, 2007 | 11:24 AM
jwcustomwurks's Avatar
jwcustomwurks
Default RE: Oil in spark plug
correct me if I'm wrong people but I believe there is a seal of some kind for the spark plug tubes that when it leaks fills the tube with oil.
Old Nov 13, 2007 | 12:05 PM
l_pillon's Avatar
l_pillon
its most likely a bad seal / gasket ....its a notorious problem.. i pulled a plug the other day and found the same thing...cleaned it all up and no probs at all...but its gonna be the seal/ gasket .....u could try some kind of sealent just to make sure it doesnt happpen anymore
Old Nov 13, 2007 | 12:24 PM
NHARINTON's Avatar
NHARINTON
its called a "spark plug tube seal"
go to autozone and but a new "valve cover gasket SET" and that will have the tube seals in it.....
make sure to tell the guy you want the kit with the tube seals.
Old Nov 13, 2007 | 08:55 PM
03neonRT's Avatar
03neonRT
ORIGINAL: NHARINTON
+1.
Old Nov 13, 2007 | 11:22 PM
dodgeneonz's Avatar
dodgeneonz
thanks guys, and sorry about the late reply... just had a rough biochem test late at night just now, but thanks man!
Old Nov 14, 2007 | 01:41 AM
neon03se's Avatar
neon03se
bio is kickin my *** lol, but i have a B!!!!
