wat now
Old Dec 4, 2007 | 05:18 PM
contagious19's Avatar
contagious19
Default wat now
ok so i took off my rear passenger rim and i notice dat my tire had excessive tire wear in the inside thread. i believe its a camber problem. does anyone know how to fix?
Old Dec 4, 2007 | 06:24 PM
Kalevra's Avatar
Kalevra
Default RE: wat now
if your car isnt lowered... there is no adjustable camber on the neons... it's probably tow that needs to be fixed. get an alignment
EDIT: from what I heard... camber has nothing to do with excessive tire ware tow in and tow out do
Old Dec 4, 2007 | 09:54 PM
I own only Dodge's Avatar
I own only Dodge
Default RE: wat now
camber will wear the tires on either edge of the tread,tow in will wear the tire across the whole tread. Where are you getting the wear?
Old Dec 4, 2007 | 11:47 PM
contagious19
Default RE: wat now
my car is lowered and its in da inner thread. so it is camber and its on my rear tire. i heard its a pain for da rear. oh and kelevra caster has nutin to do wit tire wear.
