Cam Question
Old Dec 22, 2007 | 10:08 PM
03neonRT's Avatar
03neonRT
Default RE: Cam Question
The Crane 14 is basically the same "size" as the Comp 400, it would give a slightly increased amount of power, but any extra power over the Comp 400 is generated above the stock 6750 (base) and 6815 (R/T) rev limiter. There are even l;arger cams also, like the Crane 007 and 005 which are very large custom grind cams that work well with higher compression and extensive head work.
Old Dec 22, 2007 | 11:25 PM
Chagoracing's Avatar
Chagoracing
All right
I whant build my engine with hight compression like 12.5 2.2 stroker with nitrous
the crane 005 cam will be right?
