how to decrease boost
Old Dec 11, 2007 | 05:28 PM
spikeymikey87's Avatar
spikeymikey87
Default how to decrease boost
ok i know how a boost controller works to increase boost, but how does it work to decrease boost? what is the best way to make sure the boost stays at 5psi?
Old Dec 11, 2007 | 05:36 PM
GrApHite03's Avatar
GrApHite03
Default RE: how to decrease boost
boost will only go as low as your wastegate spring allows...
Old Dec 11, 2007 | 07:46 PM
spikeymikey87
hmmm ok so say i have an srt turbo and wastegate how would i go about making the boost as low as i can and how low would that be if you know
Old Dec 11, 2007 | 07:55 PM
GrApHite03's Avatar
GrApHite03
with the stock srt wastegate spring you will not boost pass 4-5psi... feed a boost source right to the wastegate nipple. (no boost controller needed in between)
Old Dec 11, 2007 | 08:07 PM
spikeymikey87
ok that sounds easy enough. wow you answer all my questions lol nice. but how do srt owners go to 15 psi stock without a boost controller?
Old Dec 11, 2007 | 09:18 PM
GrApHite03's Avatar
GrApHite03
They have a solenoid box that the ECU controls... that actually controls the boost.
