i got another car
ORIGINAL: contagious19
yea since da body kit is pretty much destroyed, im just going to get regular bumbers. and da only time i looked at da engine it was at night so i couldnt really c. ill keep u updated on dat though
The 6 bolt motors do not walk. They are found in the 1st gen DSMs. I'd say about 80% of 2nd gen dsm guys swap in a 6 bolt. I have alot of friends that own DSMs and have worked on plenty!! One of the cleanest i've seen is my buddy Zach's who is also a moderator on my forum. He took a GST vert and swapped in the gsx awd drivetrain. Here are some pics...
1997 GSX AWD Eclipse Spyder
Engine & Components:
Built 6 Bolt Motor
Wisco 9:1/Eagle
Balance Shaft Removal
EGR Block Off
ARP Hardware
A/C Component Removal
AGP RS60t Turbocharger
Stainless Oil Feed Line
AGP Oil Return Line
DNP Exhaust Manifold
Autometer EGP Probe
TiAL 40mm External Gate
LCE 1β Dump Tube
Ported Evo3 O2 Housing
Megan Racing 3 in. Stainless DP
Apex-I N1 Cat-Back
DSMlink V2.5
PLX Wide Band System
GM 3β MAF
MAF-Translator
Prothane Motor Mounts
Walbro 255lph Fuel Pump
SBR 8an Fuel Line Kit
PTE 1000cc Injectors
Aeromotive Fuel Pressure Reg.
NGK BPR7ES Plugs
Magnecore 8mm Plug Wires
HKS EVC 5 Boost Controller
HKS 272βs Cams, Intake/Exhaust
Greddy 24R Frount Mount I/C
Dejon Tool I/C Pipes
Greddy-S BOV
New Alternator & Starter
Optima Red Top Battery
Injen Chrome Spark Cover
Injen Chrome Fuse Cover
Injen Oil /Rad/Clutch Caps
Polished/Shaved Intake Manifold
Polished Valve Cover
Polished Tanabe Strut Tower Brace
Transmission / Drive line:
AWD Swap
TRE Spec Transmission (Factory New)
4 Spider Gear Center Diff
LSD Rear Diff
Front & Rear Axels (RAXELS.COM)
New OEM Transfer Case
ACT 2600 Clutch
ACT Lightweight Flywheel
Stainless Braided Clutch Line
Prothane Tranny mounts
KYB AGX Shocks
Eibach Sportline Springs
ASA LS5 17β Wheels
BFG G-Force Tires
TPM Slotted/Drilled Rotors
Interior / Exterior / Misc.
6000k HID's
Sparco Treno 2 Seats
New Black Carpet
New Dash, Black Center Console,
Many New Misc. Interior Pieces
B&M Short Shifter
Dual Touch Screen DVD
Greddy CW Shift ****
OEM New Floor Mats
Perfect OEM Leather & Int. Panels
Autometer Pyrometer, Boost Gauges
Gauge Works Pod Bezel
New OEM Windshield
Perfect Exterior β No Dings or Scratches
Front Mud Flaps (Protect Paint From Rocks)
3M 35% Window Tint
Alpine Type-S Speakers
New Paint β Bumper / Side Skirts
Clear βEuroβ Bumper Lenses
OEM GSX Sticker on Trunk Lid
Exterior Pictures:
Engine Pictures:
[/align]
I like ecplises alot, I plan on buyinga 95-96ish one. But, not for me for my girlfriend she loves them, it will be pink an green turbo wit automatic. Im just waiting for her to get her L's and get some money to help.
as for the vacuum leak, is it an aftermarket kit?? or from the factory?? either way go look for vaccuum leaks off the wastegate, from the heat sometimesthe vacuum tubingwill crack out on ya, if not there go look at the BOV, and the vacuum sourse going to that....
ORIGINAL: GrApHite03
cool, just an FYI... DSMs are known for breaking down quite often. If modded right they can be a pretty mean car. 7 bolt motors are found in the 2nd gens like yours. The 7 bolt motor is prone to what's called "crank walk". A google search can explain alot more about it. Basically is a factory defect in the design of the crank bearings. The 7 bolts usually walk around 60,000 - 100,000 miles. can be alot sooner, but not usually later.
well it is my project and it is a damn 7 bolt. but oh well. on a sidenote my srt spoiler is gettin painted
just to make you mind wonder a bit more... The 4g64 can be found in a Hyundai Sonata. The 4g63 head bolts right on. We swapped on in my buddy's GSX... along with a 60-1 turbo that damn thing spun all four tires well into third gear.
