Sway Bar OEM upgrade?
Old Dec 17, 2007 | 04:17 PM
espelandt's Avatar
espelandt
Default Sway Bar OEM upgrade?
Looking for suggestions. Have 2000 neon. Looking to upgrade sway bars using OEM parts. Want car to be more neutral.
Stock is 20mm front and 14mm rear.
Should I upgrade rear only? Or both? if so what bars do you suggest?
Old Dec 17, 2007 | 04:56 PM
GrApHite03's Avatar
GrApHite03
Default RE: Sway Bar OEM upgrade?
Welfare Sways Set-up - (PT 26mm/ACR 19mm)
Old Dec 17, 2007 | 11:55 PM
03neonRT's Avatar
03neonRT
ORIGINAL: GrApHite03
Bingo.
Old Dec 17, 2007 | 11:56 PM
ewetho's Avatar
ewetho
The Welfare setup should maintain a fairly stock balance but if you want more neutral just get RT setup of 22/19 or maybe a SRT Front and ACR rear 24/19, both of which should be decent.
Old Dec 21, 2007 | 09:51 AM
espelandt's Avatar
espelandt
Thanks for the suggestions.
I am going to try the R/T setup.
