2001 Dodge Neon-key won't turn
Old Jan 3, 2008 | 07:14 PM
gdawg444's Avatar
gdawg444
Default 2001 Dodge Neon-key won't turn
Why can't i get the get to turn in the igniton of my 2001 Dodge Neon
Old Jan 3, 2008 | 07:36 PM
MJND1990's Avatar
MJND1990
Default RE: 2001 Dodge Neon-key won't turn
I had a similiair problem when installing my Cold air intake. Are your wheels turned all the way?? If so when you go to turn the key, pull the wheel in the direction its turned.(EX: If its all the way to the left put pressure to the left) While your doing that, turn the key. It should take the pressure of the ignition. Hope this helps.
Old Jan 3, 2008 | 07:42 PM
Kalevra's Avatar
Kalevra
tumblers might have stuck. put the key in and tap the end of the key with a little force and see if that frees it up. happened to me a few times
