rear brakes
Old Jan 6, 2008 | 09:49 PM
michael23lem's Avatar
michael23lem
Default rear brakes
does anyone know if the makea rear discbrake conversion for the 2000 neon
Old Jan 6, 2008 | 09:55 PM
contagious19's Avatar
contagious19
Default RE: rear brakes
just look for a neon in da junkyard dat has da rear disk and get it from that car, its a lot cheaper
Old Jan 6, 2008 | 10:15 PM
michael23lem
but what parts do i need of the car isn't their more than just the calipers and rotors for the rear
Old Jan 6, 2008 | 10:35 PM
Andpto's Avatar
Andpto
here is the how to write up.
http://forum.2gn.org/viewtopic.php?t=8325
The guy used the rear rotor from an srt-4. But i can imagine that you can use the rotor and cailper from any 2gn neon.
Old Jan 6, 2008 | 10:45 PM
michael23lem
thank you for the link it helped alot
Old Jan 6, 2008 | 10:50 PM
Andpto's Avatar
Andpto
your welcome
Old Jan 7, 2008 | 01:02 AM
Adionik's Avatar
Adionik
I did the rear disc swap for my 02. I had a lot of problems with the banjo bolt fitting the caliper from Autozone, but the Orileys caliper is almost a direct OEM.
It takes about 3-4 hours, which would include bleeding the brakes and swapping EVERYTHING.
LMK if you need anymore help with anything. You'll need E-Brake cables, backplates and calipers. I got all my stuff off of an 01 R/T
Old Jan 7, 2008 | 06:32 AM
Ghost Neon 2's Avatar
Ghost Neon 2
Rear calipers also require different brake lines than rear drums.
