How do i do my vacuum lines lol (i suck at this turbo stuff)
Old Jan 7, 2008 | 07:43 PM
spikeymikey87's Avatar
spikeymikey87
Default How do i do my vacuum lines lol (i suck at this turbo stuff)
ok i have a picture of the turbo
I know either the blue or red one goes to the yellow (wastegate). which one? and what do i do with the other one?
Green (surge valve) gets hooked up to a boost line on the engine side of the throttle body, or does it matter which side?
there is also a nipple on the cold side pipe from the intercooler, is that one safe to hook up to a boost guage? or should that be T'ed from the same line going to the surge valve?
Can i just hook the map sensor from my megasquirt to the same boost line as the surge valve?
i think that is it, unless I am forgetting a boost line somewhere. any ideas?
thanks a lot guys i couldnt do this without you,
-mike
Old Jan 8, 2008 | 10:58 AM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
Default RE: How do i do my vacuum lines lol (i suck at this turbo stuff)
i ran my wastegate off of my intercooler piping.., as for the surge valve, my car does not have that so i am not 100% on that, i just taped the intercooler pipe and put a 1/8 in npt fitting in it to run my wastgate... works great......
i T'd the boost gauge off of the main vaccum line of the car running to the trottle body....
good luck spikey, sorry i could not help more
Old Jan 8, 2008 | 06:50 PM
tooslow's Avatar
tooslow
run red too yellow if you have boost controller put it in between.my turbo did not have the blue one I would just plug it. for the blow off just just tee in too any vac line I used the pvc valve one. oh for the boost gauge just use the the vac line too.
Old Jan 8, 2008 | 07:51 PM
spikeymikey87
ok i heard somewhere that blue and red go to yellow and green doesnt get hooked to anything. well see if i blow up or not
Old Jan 8, 2008 | 07:56 PM
GrApHite03's Avatar
GrApHite03
i ran the yellow to my manifold... I wanted the wastegate reference to be a true boost measure. Meaning boost in the manifold, not boost anywhere before the intercooler. The other 2 i capped and didn't use.
Old Jan 9, 2008 | 10:20 PM
tooslow's Avatar
tooslow
ORIGINAL: spikeymikey87
green is the blow off valve I would hook it up
but that is just me some people like the sound of turbo spinning backwards [:'(]
Old Jan 9, 2008 | 10:44 PM
GrApHite03's Avatar
GrApHite03
ORIGINAL: tooslow
He's right. I should have mentioned i didn't use the mopar rice plate. Hence why i capped it.
