does anyone have a diagram on how to take off and install engine mounts. i'm planing to get some old stock ones from the junk. it would great if anyone could help.
well i dont have a diagram, but jack the car on jackstands, put a block of wood between a jack and your engine and jack it up a little bit. only enough to take the stress off teh mounts. technically they are called torque struts. there is one on the passenger side of the engine bay that you can see from above, and one below that in the same place on the bottom. that one is a little harder to get to
