NEEDED TO KNOW WHAT ELSE DO I NEED TO MAKE A SRT-4
Old Jan 22, 2008 | 12:59 AM
NEON01RT's Avatar
NEON01RT
Default RE: NEEDED TO KNOW WHAT ELSE DO I NEED TO MAKE A SRT-4
MY CAPS CAN STAY ON DON'T LIKE IT DON'T REPLY
Old Jan 22, 2008 | 10:51 AM
blocks885's Avatar
blocks885
LOUD NOISES! WHY ARE WE ALL YELLLLLING!!
^Gosh I love that movie!!
Old Jan 22, 2008 | 12:54 PM
blackflame's Avatar
blackflame
anchorman!!
btw, here is when to use capital letters
http://specialed.about.com/od/gramma...pitalRules.htm
Old Jan 22, 2008 | 03:53 PM
03neonRT's Avatar
03neonRT
Engine and Tranny
Complete Engine Wiring Harness
Complete Engine Bay Wiring Harness
Power Steering Pump, lines, and cooler
Clutch master and slave cylinder
Clutch/Brake Pedal assembly
Intercooler Piping
Intercooler
Radiator Hoses
Tranny, Upper and Lower Motor Mounts (the holes are larger on the the upper and lower mounts for larger bolts and the tranny mount is completely different)
SRT PCM (wont' need the bracket with 03+)
Axles (and half shaft if it isn't on the engine)
Coolant Bottle
Fuel Line (from tank to engine bay)
Fuel Pump
Flex Fuel Line (from solid fuel line to fuel rail)
Short evap hose that comes from the purge valve
All vacuum lines and the 3 selonids
o2 Sensors
Turbo Housing + O2 Housing
Lower Control Arms (they're stronger yet the same in shape)
Sentry Key Module + Key that matches the PCM VIN number.
Radiator
Some options parts would include:
SRT Power steering rack (it's shorter)
Knuckles
Flexiable Brake Lines
Calipers
Rotors
Old Jan 22, 2008 | 04:17 PM
GrApHite03's Avatar
GrApHite03
MY CAP LOCKS WAS FULL OF AWSOME BEFORE I BROKE IT.
Old Jan 24, 2008 | 08:47 PM
NEON01RT's Avatar
NEON01RT
thanks
