No power at all in my 2000 Neon
Old Jan 24, 2008 | 08:00 AM
REDEYES's Avatar
REDEYES
Default No power at all in my 2000 Neon
I got off work at 5:30am. Car started. Later in the day at 1pm. Went to the store and left the store. Car started. At 8:30pm. Went to my car. Opened the driver side door. Dome light goes on. Reach over. Put the key in the ignition while the door is still open. Turn the key. The dome light goes out. Nothing on the dash board lights up. I turn off the car. Take the key out. Dome light is still out. Place the key in the ignition. Turn the key. Nothing at all. Total silence from the front of the car to the back. I take the key out of the ignition. Then I hear four soft clicks coming from under the hood by the battery. I try to turn on my lights. No Lights. My question is. Is the battery complety dead or could it be something else? Everything in the car and under the hood and under the car is working perfectly. The battery in the car right now is from Wal-Mart and I think is three to four years old. Please help.....
Old Jan 24, 2008 | 05:46 PM
contagious19's Avatar
contagious19
Default RE: No power at all in my 2000 Neon
get ur battery tested at autozone or sumtin
Old Jan 24, 2008 | 06:02 PM
srtgtr34's Avatar
srtgtr34
currently have same problem, try giving the battery terminals a little wiggle and add some water to the battery.
Old Jan 24, 2008 | 06:44 PM
bone33's Avatar
bone33
take your battery cables off and clean the terminals and the cable ends with a wire brush.
Old Jan 24, 2008 | 07:26 PM
srtgtr34's Avatar
srtgtr34
When you first try to start your car and put the key on the "on" position you hear a poping noise or is more of a tapping?
Old Jan 24, 2008 | 07:28 PM
ewetho's Avatar
ewetho
Time to check battery cables and battery. Some seem to go just that quick. If a terminal developed a crack internally and just finished letting go you end up with a sudden failure.
Old Jan 24, 2008 | 08:45 PM
neon03se's Avatar
neon03se
ORIGINAL: srtgtr34
isn't that something you want to avoid?
Old Jan 24, 2008 | 08:59 PM
bone33's Avatar
bone33
ORIGINAL: neon03se
ORIGINAL: srtgtr34
old school batteries required you to add water sometimes, but i havent seen one of those in 20 years++
Old Jan 24, 2008 | 11:11 PM
srtgtr34's Avatar
srtgtr34
helped my battery, that gave it a far better charge. It added 5 extra days be4 it went dead. lol
Old Jan 25, 2008 | 12:06 AM
Undesolved's Avatar
Undesolved
check for corrosion and then clean em off :\ is what id say
