weird jerk in engine or transmission
Old Jan 31, 2008 | 11:27 PM
ricstee's Avatar
ricstee
Default weird jerk in engine or transmission
When car is at idle, in park or drive, I get this weird jerking from either the engine or transmission. The rpm's don't move at all, and it doesn't feel like it's going to stall. Anyone have any advice as to what it may be.
Also, for some reason, I don't need to press on the brake pedal to pull the shifter out of park, any advice on that??
Thanks a bunch.
ricstee[:@]
Old Jan 31, 2008 | 11:37 PM
Adionik's Avatar
Adionik
Default RE: weird jerk in engine or transmission
I get the same thing. It could be your motor mounts.
Honestly I would avoid Mcdonalds for a day, and spend $4 on some new spark plugs to be on the safe side. We have a low idle...so I like to check vac/ignition for this kind of stuff
