wheel barring
Old Feb 6, 2008 | 08:22 AM
noen_newbe's Avatar
noen_newbe
Default wheel barring
the wheel barring is in the axel right ?
or is it in the hub assembly? and can some one help me out with a lil quick how to get the wheel barring out and put a new one in?
like i found all the steps but i dont have access to a press
my next step is to switch the other axel
im just ganna park her for now and drive my other neon cuz i need to get brakes and a tune up oil change and change teh axel,
umm also the ***ot as mech dicked me over he broke a a screw in the frame. the screw that he broke was the screw that holds
stabalizer bar you know the one under the rack and pinion. so every time i hit a bump i here the bar come down and smack the frame
how would i go about fixing it?
Old Feb 6, 2008 | 08:29 AM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
Default RE: wheel barring
no the wheel bearing is located in the spindle, u will have to remove the axle though.....
as for the sway bar or stabilizer bar there is two booshings that mount to the frame of the car check them to see if they r worn out, if not check the sway bar links that attach to the control arm on the drivers and passanger side
Old Feb 6, 2008 | 10:12 AM
Ghost Neon 2's Avatar
Ghost Neon 2
Wheel bearing, just so you know. I replace the entire spindle, and used larger axles.
Old Feb 8, 2008 | 02:45 AM
noen_newbe's Avatar
noen_newbe
larger axels as in longer?
i dont really wanna buy another sized axel as i just put a new one on.
so the spindle thing ya takjung about is where the axel slides into? where you put that wire thru the bolt ?
lol thanks for correcting my horriable spelling dude lol
