View Poll Results: A poll
Damn, that's too good!!
16.67%
What? how? (as dumbfounded as me)
33.33%
Knew it all along
50.00%
Voters: 6. You may not vote on this poll
Urgent help needed!!! Spoke too soon
Old Feb 19, 2008 | 01:57 AM
Izero's Avatar
Izero
Default RE: Urgent help needed!!!
ur multifunction switch is shot.... if you have those 125watt bulbs in there take them out and replace ur multifunction switch and u might need to buy the repair kit from the "stealership" so yea good luck
Old Feb 19, 2008 | 02:14 AM
Kalevra's Avatar
Kalevra
what repair kit? and how do I do that? they're stock bulbs in there...
Old Feb 19, 2008 | 03:22 AM
eaks's Avatar
eaks
hey man.. i had a problem with my headlights comming on before.. i would toggle on/off as much as i wanted and nothing.. my driving lights are all that would come on.. and my gauge cluster would light up.. i would have to mess with my highbeam/lowbeam and then they would fire on.. i think i figured out why tho (this has happend twice to me).. i believe for some reason when i turned my car off my highbeam lights were on.. so then when i turned it on it must have tricked the system or something.. and i needed to mess with it.. get them on.. and always make sure u shut off your car with your lows on.. havent had an issue since i made sure i do that (since now im running HIDs with no highbeam anyways).. had the issue start about a year ago.. then the 2nd time it happend was a few months later.. figured out what happened and havent had an issue yet.. i dunno if its the same as your problem tho!
Old Feb 19, 2008 | 03:34 AM
Kalevra's Avatar
Kalevra
I messed with the high beams. I had to hold the high beams on while I drove and I tried everything to get the lights to go on... nothing...
Old Feb 19, 2008 | 03:39 AM
eaks's Avatar
eaks
did u check the bulbs? although if u needed to hold the highbeam lever then its 90% the switch thing!
Old Feb 19, 2008 | 11:42 AM
Kalevra's Avatar
Kalevra
[hr] FIXED IT!! I held the high beams on and turned the lights on and it works now!!!
Now time to explain how
I went to the stealership and they wanted 85 bucks just to diagnose it!? WTF!?! **** that... I went home and opened up my steering column ans checked the harness and on the switch side looked great... so I thought it might have been the MFS needed to be replaced. but then I remembered that someone said about the high beams being on and they switched them off and screwed it up. so I held in the high beams and switched them on... and POW! Holy SH*T! it came on!
Old Feb 19, 2008 | 12:28 PM
NHARINTON's Avatar
NHARINTON
What a pain... i need a new MFS..... i loose my gauges most of the time.... and never have running lights or dash lights...... i had to put the rear running lights on a switch so i could still drive it
Old Feb 19, 2008 | 12:33 PM
Kalevra's Avatar
Kalevra
wow... all my stuff still came on except my headlights and fogs, once i hit the highs and turned the switch, presto, they work again
Old Feb 19, 2008 | 04:49 PM
eaks's Avatar
eaks
ya man.. that might have actually been what i did to get mine working as well.. i didn't really remember.. i know i was screwing with the highbeams on/off and the light switch so thats prolly what i did.. so ya.. just dont turn your car off with your highbeams on and you should be good!!
Glad you got it fixed without any costs!
Old Feb 19, 2008 | 07:37 PM
Kalevra's Avatar
Kalevra
Ok. it happened again, this time it's fully diagnosed as the MFS. I turned on the lights, same symptoms as before... but this time if i jerk the high beams around you can see the fog light symbol pop up for a split second there for it must be that the MFS is shot
